External Object
Add an external object to the report.
- Right-click at the Report or Chapter level and select .
Or
From the Report ribbon, click the arrow next to the Add Item, then select External Object.
 - Below are the properties associated with the External Document entity.
Figure 1.- Name
 - You can edit the name property of the External Object
                                    item.Note: Once you select a file, the External Object name is replaced with the selected file name.
- File Path
 - Select an external file using the file browser option.
Note: This module works similar to the Insert Object functionality in Microsoft Word. All files listed in the Insert Object functionality of Microsoft Word are supported in this module.
Figure 2.Restriction: Adding a secured or password protected document is not supported in the External Object module.
