The following known issues will be addressed in future releases as we continuously
                improve performance of the software:
                        - Pre
                        - Contour plots for multiple loadcases cannot be shown at the same time in
                            window
                        - Eline with Single point connector will not be able to reimport
                        - Post
                        - Comparing Squeak Results from multiple load cases is not supported
                        - Comparing multiple load cases from different files with same load case
                            ID is not supported
                        - Combined Loading with a model which only consists of Squeak lines is not
                            supported
                        - Loading a model file from a network location (unless mapped to a drive)
                            is not supported
