Altair HyperGraph 2023 Release Notes
General
New Features and Enhancements
- Qt-based Build Plots dialog.
 - Implemented multiple subcase support in the Seam reader.
- Ribbon Hints
 - Ribbon hints have been added to help identify tools that have multiple
                            pick targets or open a secondary ribbon. They are small indicators that
                            appear in the ribbon between a tool’s icon and label. The number of dots
                            represents the number of pick targets in a tool, including some that are
                            hidden until hovering over the tool.
Resolved Issues
- Application closes abruptly when switching to HyperGraph after creating a curve in HyperMesh.
 - Unable to expand the Notes dialog.
 - The HWC commands related to file loading and plotting are not recorded using the new Qt-based Build Plots dialog.
 - Copying a session's page with all clients crashes the application.
 - Zoom and rotate not working for HyperGraph 3D.
 - Performance issue with Seam reader.
 - HyperGraph crashes when loading an XML file.
 - Other numerous HyperGraph issues.
Extensions
Highlights
- Extensions Release Highlights
 - Watch this video to learn more about Extension features in 2023.
- Autoloading of extensions of newly added Extensions
Enhancements
- Autoload Extensions
 - Extensions can be autoloaded using the “extends” entry when the
                            application starts or is loaded with the environment variable
HWX_PLUGINS.
Known Issues
- To show the Extension loaded in different profiles even when no GUI access
                        points like ribbons, toolbars or menus are available requires that each
                        profile is loaded with at least one entry. The example below shows the empty HyperMesh and HyperView profiles with the (dummy) entry resources. This entry will not be required in future versions to show the extension loaded in these profiles.
Figure 3.
Resolved Issues
- The “displayName” is no longer the same as the “name”
