Edit Midmesh Topology
Use the Midmesh: Edit Topology tool to edit midmesh topology.
                From the 2D ribbon, click the Midmesh > Edit Topology tool.
Figure 1. -
                Edit topology.
To edit topology by Do this Suppress edges - Set the Source selector to Lines, then select shared edges in the midmesh.
 - Click Suppress.
Imprint lines onto elements - Set the Source selector to Lines, then select CAD lines to imprint.
 - Optional: Using the Target selector, select target elements.
 - In the microdialog, select one of the
                                    following options:
- Cycle source guide surfaces (
) - Imprint normal to source guide surfaces (
) - Imprint tangential to source guide surfaces (
) - Imprint shortest distance to target (
 - Optional: In the microdialog, click
 to add, remove, and move the point
                                    handles to modify the imprint preview.- Add: click on an imprint preview line to add handles.
 - Remove: Shift + click on point handles to remove them.
 - Move: drag the point handles to move them.
 - Reset: set the handles to their initial states.
 - Optional: On the guide bar, click
 and select Align after
                                        topology edit to align edges using guide lines
                                    after imprint. - Click Imprint.
Note: If both CAD lines and midmesh shared edges are selected, the Imprint and Suppress buttons are displayed together.Create new edge Split topology to create a new edge in the following ways: - Create a new edge between two nodes.
- Set the Source selector to Nodes.
 and select Align
                                                after topology edit to align edges using
                                            guide lines after splitting. - Optional: On the guide bar, check Retain last node to retain the last node of the previous split.
 - Select two nodes.
 - Create a new edge between a node and an edge.
 and select Align
                                            guide lines after splitting. - Select a node and an edge.
                                            whether to use a shortest (
), source node to imprinted node
), tangential (
), or mixed (
) path. - Click Split.
 - Create a new edge on an FE edge
- Set the Source selector to FE Edges.
 and select Align
                                            guide lines after splitting. - Click splitedges.
