Revolve Geometry
Revolve surfaces, nodes, lines, elements, or facets around a defined axis.
- For the nodes input, based on the geometry creation mode defined, either a CAD surface or an FE geometry surface is created. While using the Revolve tool for lines or surfaces, the input determines whether a CAD surface or an FE geometry surface is created. For example, CAD lines are created as CAD surfaces, FE geometry edges are created as FE geometry surfaces.
- FE geometry solid creation for elements/facets selection is not supported at this time.
- A revolve preview for FE geometry solids is not supported at this time.
