Create and Edit Feature Edges
Use the Feature Edges tool to create and edit mesh controls on an edge.
Create Feature Edges
                From the Topology ribbon, click the Feature Edges > Create tool.
Figure 1. - Optional:
                On the guide bar, click
 to define feature
                    options.
                Select components or elements.
                Use the drop-down menu on the guide bar selector to set the entity type.
 - Click Feature.
Edit Feature Edges
                From the Topology ribbon, click the Feature Edges > Edit tool.
Figure 2. - Optional:
 to define feature
                    options.
             - Select Node Path or Node List using the guide bar drop-down menu.
                Select nodes.
Option Description Node Path - Left-click to create the path's starting point.
 - Move your mouse to draw the node path.
 - Left-click again to create the path.
Node List Left-click on individual nodes to create the desired path.  -
                Select an option from the microdialog drop-down
                    menu.
- Break ends the current node path and allows you to create a new path from a different starting point.
 - Continue starts a new node path from the end point of the previous path.
 - Click Add.
                Review open element features.
- On the guide bar, click Review.
                        Click
 and
 to cycle through open
                            loops.
                        Click
 to exit review
                            mode.
 - Optional:
                Delete feature edges in the following ways:
- Click
 on the guide bar to delete all feature edges. - Select a feature edge then left-click to delete individual feature edges.
 - Click
