Shapes
Create and edit circles and rectangles with the Shapes tool.
Define geometry preferences.
Explore the tools used to setup topology.
Explore the tools used to create topology.
Learn about creating, editing, and extracting points and nodes.
Use the Circles tool to create circles for geometry construction, edit free circles, and create/toggle filled circles, for example, disk surfaces.
Use the Rectangles tool to create rectangles for geometry construction, edit free rectangles, and create/toggle filled rectangles.
Use the Arc Lines tool to create arcs for geometry construction, edit free arcs, and create/toggle filled arcs.
A line represents a curve in space and is not attached to any surface or solid. A line is a one-dimensional geometric entity.
Use the Ruled tools to create surfaces/solids by interpolating lines and surfaces either linearly or smoothly.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying mathematical definition, specified when it was created.
Use the Extrude/Revolve tool to drag and spin lines, surfaces, and nodes in order to create surfaces or solids.
Use the Offset tool to offset surfaces, solids, lines, elements, or faces.
Use the Midlines tool to create midlines from existing lines, surface edges, or tube solids.
Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and surfaces converted from a sketch entity with the unrealize option.
Use the Ribs tool to create and modify simple ribs between two surfaces.
Use the Feature Edges tool to create and edit mesh controls on an edge.
Explore the tools used to edit topology.
The Use Parasolid option, found in multiple Topology tools, helps you in creating/editing geometries using a parasolid geometry modeling kernel.
ON THIS PAGE
ON THIS PAGE
