Use the Arc Lines tool to create arcs for geometry construction, edit free arcs, and
create/toggle filled arcs.
New arcs are organized in the same component as the entity where the center point is
placed.
When there is ambiguity, the Arc Lines tool switches between possible inferred
normals.
From the Topology ribbon, Shapes tool group, click the Arc Lines tool.
Draw an arc in on of the following ways:
- Click to place the center then drag and click to define the radius and
arc angle.
- Hold Ctrl and click to draw an arc with three
diametric points.
Tip: Press Tab to
alternate orientations.
Modify the size and location of the arc in the following ways:
Double-click on an arc to edit its dimensions.
Tip: Use snap points to snap
to pre-defined points on your model such as end, middle, center, and intersection
points.
