Use the Stitch Surfaces tool to stitch or unstitch adjacent
and intersecting surfaces.
From the Topology ribbon, Stitch tool group, click the Stitch Surfaces tool.
- Optional:
On the guide bar, click
to define stitch options.
For FE geometry, all options are supported as CAD geometry
except “Optimize surface quality”.
Stitch methods include:
- Stitch and intersect
- Finds intersections between overlapping surfaces, creates
trimming lines at the intersections, and equivalences the
resulting surface edges.
- Stitch edges only
- Performs equivalencing of edges within surfaces or/and between
surfaces. Further options like stitch free edges or stitch edges
between components or across components are available to control
stitching between edges.
- Use Parasolid
- Use Parasolid kernel to stitch edges. This option works on free
edges only and not on non-manifold or T junctions. In addition,
only surface selection is supported – clicking and dragging
edges or points has no effect. This option is useful for locally
merging edges that are less than 10 times the geometry cleanup
tolerance.
Stitch or unstitch surfaces in the following ways:
