Suppress Edges
Use the Suppress Edges tool to suppress or unsuppress edges individually or by break angle.
- Use window selection to simultaneously select multiple surfaces.
 - Use the legend in the upper-left corner of the modeling window to assist you in finding edges. Edges are color coded by type. Show and hide an edge type by toggling its corresponding checkbox on and off, or quickly isolate an edge type by clicking Only.
