Interpolate Nodes
Create evenly spaced or biased nodes by interpolating between existing nodes in space, on a surface, or on a curved or straight line.
The following figures illustrate the effect of adding five nodes between the end nodes of a line using the different bias styles with a bias intensity of 5.0.
