Remove Logos
Use the Defeature: Logos tool to find and remove logos.
Note: FE geometry is not supported for this tool.
                From the Topology ribbon, click the Defeature > Logos tool.
Figure 1. - Optional:
                On the guide bar, click
 to define settings for logo
                    detection.
                On the guide bar, click Find to detect logo surfaces in the
                        modeling window.
                For models with discrete topology, the find option is disabled; you need to manually select the base surface in the modeling window. The logo surfaces will be highlighted.
 - If you have already used the Features tool to detect logos, you can use the drop-down on menu on the guide bar to select them directly.
                Remove logos in the following ways:
- Remove all found/selected logos by clicking Remove All.
 - Remove individual logos by left-clicking.
