Perform Batch Repair
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
For Batch Repair, the parameter file is launched exposing only the geometry cleanup options. Meshing related options are hidden from as only geometry cleanup is done using this tool.
 to define batch repair
                        options
