STEP Writer
Supported Entities
- Point
- Line
- Surface
- Solid
- Part
- Assembly
- Axis system
- Fixed points. In order to export fixed points, it is necessary to convert them to free points. Then, after import, those free points must be projected onto the appropriate lines or surfaces in order to generate fixed points with the proper association.
- Vector
Export Options
@AllowDisjointShells
Value | Description |
on |
Store non-manifold geometry in one disjoint feature. |
off |
Split and store non-manifold geometries as separate joint shell features (default). |
@AssemblyMode
Parts |
Create part entity hierarchy as assembly and part entity in STEP file. |
Assemblies |
Create assembly and component entity as assembly and part entity in STEP file. |
Flatten |
Write entities in all components into a single STEP part. |
@AttributeForMaterialName
string |
Attribute created with the name contains PDM
metadata-material name information associated with the part
entity. Meaningful only if Default is "Material". |
@AttributeForMeshFlag
string |
Attribute created with the name contains PDM metadata-mesh
flag information associated with the part entity. Meaningful
only if Default is "MeshFlag". |
@AttributeForMID
string |
metadata-material ID information associated with the part
entity. Meaningful only if Default is "MaterialId". |
@AttributeForPartNumber
string |
Attribute created with the name contains PDM metadata-part
number information associated with the part entity.
Meaningful only if Default is "PartNumber". |
@AttributeForPID
string |
metadata-property ID information associated with the part
entity. Meaningful only if Default is "PID". |
@AttributeForRevision
string |
metadata-revision information associated with the part entity.
Meaningful only if Default is "Revision". |
@AttributeForThickness
string |
metadata-thickness information associated with the part entity.
Meaningful only if Default is "Thickness". |
@AttributeForUID
string |
Attribute created with the name contains the PDM metadata-UID
information associated with the part entity. Meaningful only
if Default is "UID". |
@Export
All |
Export all geometry (default). |
Displayed |
Export displayed geometry only. |
@GeometryMode
Standard |
Write CAD geometry with standard types such as cylinder, cone, circle, and so on (default). |
BSpline |
Convert all surface geometry data into NURBS. This option may increase the output file size and be time consuming depending on the actual geometry. |
@HMOrignalIdAsAttribute
on |
Write HyperMesh entity Identifier as HM_ORIGINAL_ID attribute |
off |
Do not export HyperMesh entity Identifier (default). |
@LayerMode
None |
No special layer handling is performed (default). |
ComponentID |
The entities in each component will be assigned to the
layernumber in the STEP file corresponding to that
component ID. |
@MetadataPrefixFilter
string |
The prefix to use to find metadata to export. Only metadata with the specified prefix is exported. Any metadata without this prefix is not exported. Default is empty, meaning all metadata will be exported. |
@NameFromRepresentation
on |
Assign part name in CAD file from the representation file
name attached to part entity. Meaningful only if
off |
Assign part name in CAD file is assigned from the part entity
name in the application. Meaningful only if
@OptimizeForCAD
on |
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology before export, and check the topology of the model for gaps that are larger than a given tolerance between shared, non-manifold, or suppressed edges. If the gap is found to be bigger than the tolerance, the surface and edge geometries are morphed parametrically and in 3D, if necessary, to make the gap smaller than the tolerance. In addition, non-essential degenerate edges are removed. This also modifies the geometry within the application (default). |
off |
Do not perform the optimization steps. |
@RemoveMetadataPrefix
on |
Remove the metadata prefix for export. Meaningful only if
off |
Do not remove the metadata prefix for export
(default). Meaningful only if
@SourceUnits
Unit system assigned to the data present in the application during export |
@StepHeaderAuthorInfo
string |
String to use for the AUTHOR field in the STEP header. |
@StepHeaderAuthorizationInfo
string |
String to use for the AUTHORIZATION field in the STEP header. |
@StepHeaderOrganizationInfo
string |
String to use for the ORGANIZATION field in the STEP header. |
@TargetUnits
Units System in the exported STEP file. |
@TopologyMode
Solid/Shell |
Export topology data similar to the application's topology data, keeping the distinction between solids and shells (default). |
Surface |
Export each surface, including solid faces, as a single surface, effectively neglecting connectivity. |
@Version
string |
The STEP version to use for export. Valid versions are AP214 (default). |
@WriteColorFrom
string |
Specify colors for the geometrical entities during export.
Colors are supported at the component level only, whereas
individual entity colors (points, lines, surfaces, solids) are
not supported. Valid values are Component (default) and Metadata. |
@WriteMetaDataAsColor
string |
Specify the metadata to use for coloring entities. Default
is Meaningful only if
@WriteMetaDataAsName
string |
Specify the metadata to use for naming entities. Default
@WriteNameFrom
string |
Specify names for the geometrical entities during export.
Names are supported at the component level only, whereas
individual entity names (points, lines, surfaces, solids) are
not supported. Valid values are Component and Metadata (default). |
