JT Writer
Supported Entities
- Point
 - Line
 - Surface
 - Solid
 - Part
 - Assembly
 - Elements are exported as tessellations as follows:
- tria3 elements
 - quad4 elements, each split into two triangles
 - tetra4 element faces
 - penta6 element faces, with each quad face split into two triangles
 - hex8 element faces, with each face split into two triangles
Export Options
The JT export option is extensively used inside CAD modeling and PLM systems to quickly visualize a products structure and to compare changes between revisions of CAD and FE models. Select the JT export option to export all of the model's geometry and FE element information, component organization, and property color.
The JT writer uses the jt_writer.ini file with the following available options:
| Value | Description |
on |
                            Store non-manifold geometry in one disjoint feature. |
off |
                            Split and store non-manifold geometries as separate joint shell features (default). |
Parts |
                            Create part entity hierarchy as assembly and part entity in JT. |
Assemblies |
                            Create assembly and component entity as assembly and part entity in JT. |
Flatten |
                            Write entities in all components into a single JT Part. |
n
string |
                            Attribute created with the name contains PDM metadata-material
                                name information associated with the part entity. Meaningful only
                                    if  Default is "Material".  |
string |
                            Attribute created with the name contains PDM metadata-mesh flag
                                information associated with the part entity. Meaningful only if
                                         Default is "MeshFlag".  |
string |
                            Attribute created with the name contains PDM metadata-material ID
                                         Default is "MaterialId".  |
string |
                            Attribute created with the name contains PDM metadata-part number
                                         Default is "PartNumber".  |
string |
                            Attribute created with the name contains PDM metadata-property ID
                                         Default is "PID".  |
string |
                            Attribute created with the name contains PDM metadata-revision
                                         Default is "Revision".  |
string |
                            Attribute created with the name contains PDM metadata-thickness
                                         Default is "Thickness".  |
string |
                            Attribute created with the name contains the PDM metadata-UID
                                         Default is "UID".  |
on |
                            Create tessellations even when no mesh is exported (default). |
off |
                            Create just the tessellations corresponding to the exported mesh. |
all |
                            Export all geometry (default). |
displayed |
                            Export displayed geometry only. |
Monolithic |
                            Create a single JT file. |
PerPart |
                                 Create a JT file “Per part”. For example, there is a JT file containing the main assembly and each part is stored in an individual JT file in a subdirectory with the same name as the main JT file (default).  |
Standard |
                            Write CAD geometry with standard types such as cylinder, cone, circle, and so on (default). |
BSpline |
                            Convert all surface geometry data into NURBS. This option may increase the output file size and be time consuming depending on the actual geometry. |
string |
                            Prefix to use to find metadata to export. Only metadata with the specified prefix is exported. Any metadata without this prefix is not exported. Default is empty, meaning all metadata will be exported. |
on |
                            Assign part name in CAD file from the representation file name
                                attached to part entity.  Meaningful only if
off |
                            Assign part name in CAD file from the part entity name in
                                HyperMesh.  Meaningful only if   |
on |
                            Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology before export, and check the topology of the model for gaps that are larger than a given tolerance between shared, non-manifold, or suppressed edges. If the gap is found to be bigger than the tolerance, the surface and edge geometries are morphed parametrically and in 3D, if necessary, to make the gap smaller than the tolerance. In addition, non-essential degenerate edges are removed. This also modifies the geometry within the application (default). |
off |
                            Do not perform the optimization steps. |
on |
                            Remove the metadata prefix for export. Meaningful only if
off |
                            Do not remove the metadata prefix for export
                                    (default). Meaningful only if
                            Unit system assigned to the data present during export. |
                            Units System in the exported JT file. |
Solid/Shell |
                            Export topology data similar to the application's topology data, keeping the distinction between solids and shells (default). |
Surface |
                            Export each surface, including solid faces, as a single surface, effectively neglecting connectivity. |
string |
                            The JT version to use for export. Valid versions are 10.2 (default), 10.1, 10.0, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.1, 8.1, 8.0, 7.0 or 6.4. |
string |
                            Specify colors for the geometrical entities during export. Colors
                                are supported at the component level only, whereas individual entity
                                colors (points, lines, surfaces, solids) are not supported. Valid values are Component (default) and Metadata.  |
string |
                            Specify the metadata to use for coloring entities. Default is
                                         Meaningful only if
string |
                            Specify the metadata to use for naming entities. Default is
                                         Meaningful only if
string |
                            Specify names for the geometrical entities during export. Names
                                names (points, lines, surfaces, solids) are not supported. Valid values are Component and Metadata (default).  |
