Supported Entities
            Entities supported by the
IGES writer.
                    - Subfigure Definition (308)
                    - Singular Subfigure Instance (408)
                    - Composite curve (102)
                    - Plane (108)
                    - Line (110)
                    - Point (116)
                    - Rational B-spline curve (126)
                    - Rational B-spline surface (128)
                    - Curve on a parametric surface (142)
                    - Trimmed (parametric) surface (144)
                    - Form 7 group without back pointers (402)
                    - Transformation Matrix (124)
                    - Name Property (406 Form 15)
                    - Color Definition (314)
            Fixed points (those associated with lines or surfaces) are not supported by the
                    IGES standard and are not exported. In order to
                export fixed points, it is necessary to convert them to free points. Then, after
                import, those free points must be projected onto the appropriate lines or surfaces
                in order to generate fixed points with the proper association.
        Export Options
            When IGES data is exported, it writes lines in a form
                resembling the database. Each segment on the line becomes a separate curve in
                    IGES. If there is more than one segment in the
                line, the resulting curves in IGES are joined
                together with a composite curve entity. NURBS curves and ellipses are written as
                rational b-spline curves (IGES's rational B-splines
                are general NURBS).
            Surface faces that comprise each surface are written to allow for output type
                options. NURBS surfaces are output as rational B-spline surfaces in IGES are cones, spheres, and tori. If necessary, curves on
                parametric surfaces and trimmed surface entities are used to trim the NURBS
                surface.
            The IGES writer uses the
iges_writer.ini file with the following
                available options:
@AssemblyMode
                                | Value |
                                Description |
                                Parts |
                                Create subfigure definition entity (308) and singular
                                    subfigure instance entity (408) from the part entity
                                    (default). |
                                Assemblies |
                                    subfigure instance entity (408) from the assembly
                                    entity. |
                                Layers |
                                Send each component as a different layer (level) in the
                                        IGES file. This is the most
                                    efficient format. |
                                Groups |
                                Send each component as an associative instance entity (type
                                    402, form 7). |
                                LayersAndGroups |
                                Send each component as a different layer (level), and send
                                    each set of faces comprising one surface as an associativity
                                    instance (group). |
@AuthorName
                                | Value |
                                Description |
                                string |
                                String to write in the IGES
                                    author name field.  Default is
                                    Unknown.
@AuthorOrganization
                                | Value |
                                Description |
                                string |
                                    author organization field. Default is
                                        Unknown.
@Export
                                | Value |
                                Description |
                                All |
                                Export all geometry (default). |
                                Displayed |
                                Export displayed geometry only. |
@NameFromRepresentation
                                | Value |
                                Description |
                                on |
                                Assign part name in CAD file from the representation file
                                    name and attach it to the part entity.  Meaningful only if
                                            AssemblyMode =
                                        "Parts".
                                off |
                                Assign part name in CAD file from the part entity name in the
                                    application.  Meaningful only if AssemblyMode =
                                            "Parts".
@OptimizeForCAD
                                | Value |
                                Description |
                                on |
                                Fix gaps between stitched edges and vertices to make the
                                    actual geometry of the surfaces consistent with the model
                                    topology before export, and check the topology of the model for
                                    gaps that are larger than a given tolerance between shared,
                                    non-manifold, or suppressed edges. If the gap is found to be
                                    bigger than the tolerance, the surface and edge geometries are
                                    morphed parametrically and in 3D, if necessary, to make the gap
                                    smaller than the tolerance. In addition, non-essential
                                    degenerate edges are removed. This also modifies the geometry
                                    within the application (default). |
                                off |
                                Do not perform the optimization steps. |
@OuterLoop
                                | Value |
                                Description |
                                Optional1 |
                                The IGES 6.0 standard allows
                                    you to default to the natural outer loop of the surface being
                                    trimmed. If you are trimming a NURBS surface with several holes
                                    and no exterior trimming, the outer loop can be left out of the
                                        IGES file, making the surface
                                    representation shorter and more accurate. Use this option if it
                                    is supported by your IGES
                                    post-processor (default). This is not available with the JAMA-IS
                                    standard. |
                                Mandatory2 |
                                For those post-processors that do not allow an optional outer
                                    loop, this option forces an outer loop to be written for trimmed
                                    surfaces. |
@SourceUnits
                                | Value |
                                Description |
                                        MKS (m kg N s)
                                        MMKS (mm kg N s)
                                        MPA (mm t N s)
                                        CGS (cm g dyn s)
                                        MMKNMS (mm kg kN ms)
                                        MMGNMS (mm g N ms)
                                        IPS Std (in pounds lbf s)
                                        IPS Grav (in slinch lbf s)
                                        FPS Std (ft pounds lbf s)
                                        FPS Grav (ft slug lbf s)
                                Assign a unit system to the data present during
                                    export. |
@TargetUnits
                                | Value |
                                Description |
                                        Microns
                                        Millimeters
                                        Centimeters
                                        Meters
                                        Kilometers
                                        Microinches
                                        Mils
                                        Inches
                                        Feet
                                        Miles
                                Units system written in the IGES file. |
                    - The most efficient form is JAMA planes and the Outer Loop Optional option;
                        however, this choice may cause compatibility difficulties.
                    - To be JAMA-IS compatible, select the JAMA planes and the Outer Loop
                        Mandatory options.
