Make Entities Current
Determine which collector new entities are placed in.
Available for the following entity types in HyperMesh: includes, parts, components, load collectors, system collectors, and beam section collectors.
- Select an appropriate entity then right-click and select Make Current from the context menu.
 - Click one of the collector buttons on the status bar and select an entity from the dialog or the modeling window .
