Basic Entity Operations
Learn the basics of working with entities.
Explore the user interface.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools and browsers that are available from the ribbons, as well as create entities and solver cards.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities.
Add entities to the model.
Modify entity parameters.
Remove entities from the model.
Duplicate selected entities.
Change the name of entities.
Change the display color of entities in the modeling window.
Determine which collector new entities are placed in.
Edit an entity's card. You can edit multiple entities provided they use identical card images.
In Review mode, you can review selected entities irrespective of their display state.
Open the Reference Browser and display the relationship of selected entities to other entities in the model in a hierarchical tree structure.
Set various states for entities in a model.
Learn how to work with entities using the Entity Editor.
Define the mandatory, default value, and/or hidden state settings for entity attributes.
Use the tools in the Home ribbon group menu to transform, mirror/reflect, and adjust the dimensions of entities.
Add metadata to all types of entities. The added metadata can be saved to an *.hm file.
Undo and redo actions.
Default keyboard shortcuts and mouse controls.
Supported SpaceBall or SpaceMouse devices.
ON THIS PAGE
ON THIS PAGE
