Create Entities
Add entities to the model.
                Do one of the following:
- Click
 in an entity view browser. - Right-click in empty space in a browser and select Create > <entity> from the context menu.
 - Right-click on a parent level entity folder in a browser and select Create from the context menu.
 - Set an entity selector to the desired type, then
                        right-click in the modeling window and select
                            Create <entity> from the context menu.Note: Not available for all entity types.
(HyperMesh only)
 - Select a tool used to create entities on a ribbon.
The entity is created and assigned a default name, ID, and color. - Click
 - Define the entity's parameters.
