FBD Trace Plot
Display free-body forces and moments at each cross-section along a node path.
- FBD Section Group
 - Define one or more cross-section groups.
 - Properties
 - Shows all properties of a selected FBD section group
 - Loadcases
 - List of subcases available inside all imported result files
 - Trace Plot and Display
 - Visualization options
- Create a FBD section group
 - Set the properties of the selected cross-section group
 - Select a loadcase
 - Set the options for the trace plot
 - Display the trace plot for the selected loadcase
Create Free-Body Sections
- Name
 - The name of the FBD section group.
 - Select Node Path
 - Select a node path for the FBD section group.
 - Select Intersect Entity
 - Select elements of interest along the node path for the FBD section group. Cross-sections on the FBD Forces tool use all elements intersecting the plane. However, the Trace Plot tool allows you to specify what elements will be considered.
 - Number of cuts between nodes
 - Defines the amount of extra cross-sections between each pair of selected nodes.
 - Cutting plane definition
 - Defines the normal direction of all cross-sections created by the Trace Plot tool.
 - Direction
 - Available when the cutting plane definition is set to common direction. Defines a vector to be used as the normal direction for all cross-sections.
 - System definition
 - Defines the system used to evaluate results.
All FBD section groups display in the Model Browser.
Set Properties of the Selected FBD Section Group
- Name
 - The name of the FBD Section Group.
 - ID
 - The ID of the FBD Section Group.
 - Color
 - The color of the FBD Section Group.
 - Intersect entity ids
 - Select elements of interest along the node path for the FBD Section Group.
 - System definition
 - Defines the system used to plot results.
 - System
 - Available when the system definition is set to User defined. Selects a coordinate system to plot results.
 - Orientation Vector
 - Available when the system definition is set to Direction based. Defines the orientation vector to define the XY plane.
Select a Loadcase
Trace Plot Visualization Options
Define visualization options for the trace plot.
- Load Types
 - Select what type of free-body data must be shown.
 - Tolerance
 - Forces or moments with an absolute value lower than the tolerance are not displayed.
 - Force/Moment
 - Defines what force or moment component will display.
 - Arrow Length (%)
 - Scales trace plot for visualization.
 - Numeric format
 - Defines if trace plot values will display in fixed or scientific format. Also defines the amount of decimal places.
 - Plot Direction
 - Selects the direction of the trace plot.
 - Sum At
 - Selects if forces and moments will be summed at the centroid or at nodes.
 - Display At
 - Selects if forces and moments will display at the centroid or at nodes.
 - Show values
 - Select to display trace plot values.
Display the Trace Plot for the Selected Loadcase
- Click Apply to show the trace plot.
 - Click Clear to hide the trace plot.
Figure 3.
