FBD Bar Plot
Display forces and moments acting on beam and bar elements.
- Free Body Sections
 - Define one or more free-body sections.
 - Properties
 - Shows all properties of a selected free-body section.
 - loadcases
 - List of subcases available inside all of the imported result files.
 - FBD Plot and Display
 - Visualization options.
- Create a free-body section.
 - Set the properties of the selected free-body section.
 - Select a loadcase.
 - Set the options for the bar plot.
 - Display the bar plot for the selected loadcase.
Create Free-Body Sections
Set Properties of the Selected Free-Body Section
- Name
 - The name of the free-body section.
 - ID
 - The ID of the free-body section.
 - Color
 - The color of the free-body section.
 - Entity List
 - Select bar and beam elements for the free-body section.
Select a Loadcase
Bar Plot Visualization Options
Define visualization options for the bar plot.
- Bar Plot
 - Select if the bar plot will show on nodes or elements. Select forces and moments that will display.
 - Force/Moment Diagram
 - Select forces and moments that will display. Select the plot direction.
 - Create Envelope
 - Activate the checkbox to create an envelope using multiple loadcases.
 - Show values
 - Activate the checkbox to display values.
 - Size Scaling
 - Defines how bar plot vectors will be scaled for visualization.
 - Arrow Length (%)
 - Scales bar plot vectors for visualization.
 - Color
 - Change the color of forces and moments.
 - Vector heads
 - Defines if the bar plot vector points to a point or out of it.
 - Vector styles
 - Change the style of bar plot vectors.
 - Numeric format
 - Defines the numeric format of the values shown.
 - Tables
 - Creates tables with forces and moments for one or multiple free-body sections and for one or multiple loadcases.
Display the Bar Plot for the Selected Loadcase
- Click Apply to show the bar plot.
 - Click Clear to hide the bar plot.
Figure 5.
