Use the FBD Manager to create pairs of entities, <field, table>. Translational
degrees of freedom and Rotational degrees of freedom are separate fields. This tool creates
a field per loadcase and free-body section.
From the Post ribbon, select the FBD Manager tool from
the Plot group.
The FBD Manager dialog opens.
Select free-body sections.
Select loadcases to consider.
From the Options tab, define the Tolerance.
From the Export tab, select Free body
forces/moments, Grid point
forces/moments, or
Displacement/Rotation.
If Grid point forces/moments is selected, select
relevant contributions to take into account.
Click
The Create Fields from FBD dialog
opens.
Select sources to create field based on result type and click
Create.
