Built-In Library of Methods
By default, HyperMesh comes with a set of methods. These methods are always available even if you register your own custom methods.
- Rivet: JointLoad: Only supported for op2 and xdb
 - Panel Metallic: Panel_FailureMode, Panel_ShearBuckling: Only supported for op2 and xdb
 - Panel Composite: First Ply Failure: Supported for op2, h3d and xdb
 - Beam: Stringer Axial Stress, Stringer Buckling, Stringer Axial Stress FBD, Stringer Buckling FBD: Only supported for op2 and xdb
