Create Generic Structural Elements
Use the Generic tool to collect elements and free body sections in designpoints.
                From the Certification ribbon, click the Generic
                    tool.
Figure 1. -
                Select entities to collect.
                For components, parts, and sets (element sets only), the method is evaluated on the entity's associated elements.
 - Optional:
                On the guide bar, click
 to select a Split
                    option.
                For elements, you can create designpoints based on the element’s property or component.For all other entity types, you can create either a single designpoint with the collection of selected entities or create a designpoint per entity.
 - Optional:
                Select a destination DesignPointSet to hold newly created designpoints.
                If no set is selected, a new one is created with config Generic.
If you enter this menu from the Certification Browser context menu using Auto DDP, the selector is pre-populated with the selected designpointset.
 - Specify a structuralproperty entity to assign.
                On the guide bar, click one of the following:
 - Save changes and stay in the tool.
 - Save changes and close the tool.
