Assign Methods
To run methods on designpointset entities, the methods must first be assigned. Creating methods simply adds new designpointmethod entities to the database, but no reference is added to any designpointset.
A method (designpointmethod entity) can be assigned to a single designpointset at a time. When a designpointmethod entity selected to be assigned is already in use, a deep copy is first created and assigned to the destination. If multiple destinations are selected, a copy of the method per destination is created.
- Method entities
 - Structural properties
 - Properties
 - Materials
If the extended entity is either a property or a material, the tool scans the structural properties and searches if a property is assigned to it; otherwise, it selects an elemental property from elements inside the structural element. The collected list of properties/materials referenced by structural elements in the designpointset where a method is assigned are extended by metadata if they did not exist before.
Metadata is visible in the Entity Editor (of extended entity) under the category Metadata Values.
User inputs on methods or structural properties results in new attributes appended to the list of regular entity attributes.
