MPDB Tool Results
Figure 1. Standard Deviation Calculation
Figure 3.
Figure 4.
Figure 5.
- Output.key or output_0000.rad
 - Solver input file containing the deformed shape of the barrier at the selected time step.
 - outputreference_plate.key or outputreference_0000.rad
 - Solver input file containing the reference plate defining the Grid for the projection calculation.
 - export_barrier_reference.key or export_barrier_reference_0000.rad
 - Solver input file containing the deformed shape of the barrier at the selected time step and the GRID used for the projection calculation.
 - outputprojection.hwascii
 - ASCII results file containing the nodal or elemental projection values along with their entity IDs.
 - MPDB_session_file.mvw
 - Session file with results.
 - Bottoming_Out_Data.csv
 - Text file containing bottoming out data (if a bottoming out scenario is found) - node IDs and their corresponding projection values within a 40mm x 40mm area.
 - *.pptx
 - Automatic PPT report generated by MPDB tool containing Standard deviation, OLC and modifier plots.
