FMVSS201_ECE-R21
- Solver Result
 - From the drop-down menu, select Radioss or LS-DYNA.
 - Vehicle Direction
 - Select X or Y for the direction that you want to cut the section.
 - Clip Threshold Value
 - Enter a clip threshold value. The maximum value is 72.
 - SAE Filter
 - To apply an SAE filter, activate the Use SAE
                                filter option and select one of the following SAE
                                filters:
- SAE 60
 - SAE 180
 - SAE 600
 - SAE 1000
 - SAE general
 - SAE mirror
 - IP Deck Directory
 - Use the file browser to select the result file.
 - Target Point CSV
 - Select a .csv file that contains target point data.
 - Mode
 - Select Append, Overlay or Replace.
 - Load Defaults
 - Loads previously-saved entry options.
 - Save Defaults
 - Saves the current entry options as the default.
 - Generate
 - Click Generate to plot your results based on your selections. The following dialogs are displayed:
 - Generate Report
 - Upon plotting your results, click Generate Report to output your result data to a PowerPoint PPT file, which contains your project details, results table, and plot images.
 - Close
 - Click Close to close the browser tab.
