Contour time of failure or failure status of elements.
      Failure Time is a special scalar result type that is created by
HyperView based on Erosion (failed elements) data available in the
        result file. No extra step is required; if the results contains Erosion, then a data type
        called FailureTime is automatically created.
Attention: This is available in the HyperView - MultiCore profile
          only.
        Note: The FailureTime contour plot is based on the steps that have
          been loaded. For example, assume that a simulation has 50 steps, and no element fails in
          the first 10 steps. If only the first 10 steps are loaded and FailureTime is contoured,
          then the plot would show N/A. Therefore, it is recommended that all the steps of the
          simulation be loaded before loading FailureTime in order to display precise failure
          information on an element.
