Access the HyperView - MultiCore Profile
- To access the HyperView - MultiCore profile on
                    Windows, select  from the Start menu.
- From the Startup dialog, select HyperView and use the Profile drop-down menu to select the MultiCore profile.
 - Click Create Session.
                    Linux, run
hvmcfrom the <install_dir>/altair/scripts directory.
This will set the proper environment to run the MultiCore infrastructure.
