Tracing
Use the Tracing tool to trace system, component, and node entities during animation.
        Figure 2. Tracing PanelView new features for Altair HyperWorks 2023.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
        Figure 2. Tracing Panel© 2023 Altair Engineering, Inc. All Rights Reserved.
