Attach a Note to an Entity
                From the Annotate tools, click the Notes tool.
Figure 1. -
                Right-click on the note to be attached to another entity and select
                        Edit.
                    Figure 2. Note Context Menu -
                From the floating entity editor, select the Attach Type as
                        Entity.
Figure 3. Note Entity Editor - Use the Entity ID drop-down menu to select the Entity type.
                Select the entity.
- Click the input collector (Node, Element, Component, or System) and
                        select By ID.
OR
 - Pick an entity (node, element, component, or system) directly from the model in the modeling window.
                        select By ID.
 - Once selection is complete, close the Entity Editor.
