Rename a Derived Load Case
                Do one of the following:
- Click the Loadcase tool.
Figure 1. - Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - Click the Loadcase tool.
 - From the Derived load case drop-down menu, select a load case to make it active.
                Click Rename.
                The Rename dialog is displayed.
 - Type a new label in the text field and press Enter.
