Remove Load Cases or Simulations from a Derived Load Case
                Do one of the following:
- Click the Loadcase tool.
Figure 1. - Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - Click the Loadcase tool.
 - Select one or more simulation time steps from the derived load case list.
                Click the left blue arrow
                    (remove button).
                The simulation time steps are removed from the list.
