Masking Simulation Data
- Load a simulation using the Load Model panel.
 - Display the blank components for which a Forming Limit Diagram (FLD) is to be plotted.
                Define or load a forming limit curve (FLC).
                An FLC is displayed in a separate 2D window for you to preview.Tip: For comparison purposes, you can create additional FLD studies on the same model using various FLC definitions.
                Return to the FLD panel and create an FLD using a reference FLC.
                The following items are displayed: the FLC, the safety curve, ±45 degree lines, and the elemental major and minor strains for the selected components in an xy-plot.
 - Optional:
                Click the Query elements icon
 to
                    select individual elements on the model, which are then highlighted on the
                    forming limit diagram.
             - Optional:
                Click the Query FLD plot icon
                    to open the Coordinate Info panel where you can select curve points that will
                    then be highlighted on the formability contour.
             - Optional:
                Click the Trace strain path of element
 to select element(s) on the model and trace their
                    deformation path in the Forming Limit Diagram.
