Manage Section Definitions
                Sort the sections in the Section table/list by clicking on the heading of each
                    column. For example, click the Label heading to sort
                    alphabetically by name.
                Tip: Repeated clicks on the column heading will toggle between ascending and descending order.The section table/list contains the following headers and column information:
- Label
 - The label for the section.
 - Sum point
 - The selected summation node about which the grid point data is being summed.
 - System
 - The specified coordinate system into which the grid point vector results are being transformed and output
 - Review
 - Activate this check box to highlight the currently selected element/node section, summation point, and result system in the modeling window. This allows you to verify a section definition.
 - Color
 - Select/change the review color of the section using the color box and palette.
                Select a section, or multiple sections, from the Section table/list.
                Note: Multiple sections can be selected in the table/list using the standard CTRL/SHIFT+click functionality.Tip: You can use the All, None, Reverse buttons to quickly select/deselect sections in the Section table/list.
 - Define or modify the selected section(s).
