Access the Context Menu
                From the FBD tab, right-click anywhere within the Section table/list.
                The context menu is displayed.
                Click on one of the available options.
Option Description Show Displays the selected section(s) in the modeling window and leaves the corresponding Review check box(es) state unaltered. Hide Hides the selected section(s) in the modeling window and deactivates the corresponding Review check box(es). Isolate Displays only the entities in the selected section, unchanging the state of the corresponding Review check box(es), while also turning off all other entities of the same type and their corresponding Review check box(es). Select All Selects all of the sections in the table/list. Rename Renames the selected section.
