Deleting a Collision Set
                Select a collision set from the Collision Sets list.
                Note: Multiple collision sets can also be selected.
                Delete the collision set(s) using one of the following methods.
- Click Delete (located at the bottom of the panel).
 - Press the Delete key on the keyboard.
The collision set is removed from the list.
