Accessing the Context Menu
                From the Collision Detection panel, right-click anywhere within the Collisions
                    Sets list.
                The context menu is displayed.
                Click on one of the available options.
Option Description Delete Deletes the selected collision set(s) from the list. Rename Displays the Rename dialog, which allows you to rename the selected collision set. Make Current Allows you to select which collision set will be activated and displayed in the modeling window. This option performs the same action as clicking the radio button "on" next to a collision set.
