Result On Stack
Use the Result on Stack tool to display layer based shell results along with the real stacking sequence of the selected element(s).
Next, you have to contour the needed result in a contour plot and then you can run the application.
- Quick Query
- Append Multiple Results
Quick Query
- OptiStruct (zone and ply based)
- Radioss
- Nastran
- LS-DYNA
- Abaqus
