Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
When using the soft soil interaction method, if the track link
geometry features different dimensions from the ones specified in the track properties, it is
required to use the update link geometry option.
Figure 1. Update Link Geometry dialog
The default option is set to Auto Calculate, this option
considers the parameters specified in the track properties section. In case of different
track link geometry, the User Input option allows modify the
dimension of the track link.
Figure 2. User input option in Update Link Geometry dialog
The contact points define how many points will represent that track link. The
maximum points allowed in the model is five. The figure below illustrates the track links
with 2, 3, 4, and 5 points.
Figure 3. Contact points available in Update Link Geometry
The figure below shows an example of a CAD track link using 2 contact points
and the equivalent parameters in the Update Link Geometry dialog.
