Rolling Systems
- Sprockets/Double Sprocket
- Profiled wheel with teeth, or cogs, that mesh with a track.
- Idler
- A wheel that is used to alter the path of the track or to increase the wrap angle.
- Roller
- A small wheel used to prevent the catenary hang of the track and support the load of the track.
- Wheel/ Double Wheel
- Transfers the vehicle weight to the track.
Mass and inertia for the rolling system are calculated based on the provided geometric dimensions or CAD Graphics. Alternatively, user-defined mass and inertia can be provided using the option User mass, inertia rolling element, in this case the rolling systems bodies must be edited to include the mass and inertia properties.
The properties of the rolling system can be modified in the dataset under the rolling system after the system has been created.
