| Air Spring
                    - Limit force in suspension components
                    - Maintain ride height for large variations in load
                    - Absorb the impact from the vertical road inputs
                    - Exerts a force along a line between two bodies
                    - Non-linear force versus deflection at different static inflation pressures
                      interpolated from tabular data stored in a property file
                    - Set the initial load and spring height to determine the static inflation
                      pressure
                | Helical Spring
                    - Non-linear force versus deflection interpolated from tabular data stored in
                      a property file
                    - Set the initial load or length of the spring at vehicle input position
                | Shock Absorber
                Dissipate the energy stored in springs and damp the chassis motions  |
                    - Include rebound and bump stops to limit the shock absorber actuation
                      a property file
                    - Linear force versus velocity
                | Mount Bushing
                Elastically mount vehicle components to the vehicle chassis or body |
                    - Exerts force and torque all directions
                      a property file
                    - Linear damping
                | Frequency Dependent Bushing
                    - Exerts force and torque in all directions
                    - Stiffness and damping dependent on amplitude and frequency of bushing
                      displacement
                    - Non-linear static force/torque versus deflection
                | Bump Stop
                Limit suspension bump travel |
                    - Exerts a force along a line to repel two bodies when the distance between
                      the bodies is less than a threshold
                      a property file
                    - Linear Damping
                | Rebound Stop
                Limit suspension rebound travel |
                      the bodies is greater than a threshold
                      a property file
                    - Linear Damping
                | Rider
                Model the mass and inertia of a vehicle driver and passengers |
                    - Adjustable height and body density
                    - Position knees, ankles, elbow, hip, hand, wrist, pelvis, neck to mimic
                      different postures
                | Tire
                    - Develop the contact forces from the ground for carrying vehicle load,
                      steering, accelerating, and braking
                    - Isolate vibrations from small road irregularities
                    - Altair Fiala tire
                    - Altair Soft-Soil tire
                    - CD-Tire
                    - Cosin FTire
                    - Siemens tire (MF-Tyre)
                    - Different road models support, including 3D and 2D, soft-soil, Curved
                      Gridded Road (crg), Cosin RGR, CD-Tire, and point cloud data
