Wheel Center Rotational Stiffnesses
Request Number: 80000060
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel Center XX Stiffness | N-m/deg | The left wheel center rotational stiffness about the global longitudinal axis
                      or: 1/C(4,4)/rtod/1000  |
| F3 | RESULT(3) | Left Wheel Center YY Stiffness | N-m/deg | The left wheel center rotational stiffness about the global lateral axis
                      or: 1/C(5,5)/rtod/1000  |
| F4 | RESULT(4) | Left Wheel Center ZZ Stiffness | N-m/deg | The left wheel center rotational stiffness about the global vertical axis
                      or: 1/C(6,6)/rtod/1000  |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Right Wheel Center XX Stiffness | N-m/deg | The right wheel center rotational stiffness about the global longitudinal
                  axis or: 1/C(10,10)/rtod/1000  |
| F7 | RESULT(7) | Right Wheel Center YY Stiffness | N-m/deg | The right wheel center rotational stiffness about the global lateral axis
                      or: 1/C(11,11)/rtod/1000  |
| F8 | RESULT(8) | Right Wheel Center ZZ Stiffness | N-m/deg | The right wheel center rotational stiffness about the global vertical axis
                      or: 1/C(12,12)/rtod/1000  |
