| F1 |
                RESULT(1) |
                Not Used |
                Not Used |
                Not Used |
                | F2 |
                RESULT(2) |
                Left Front Anti-Lift or Left Rear Anti-Squat |
                The resistance to lifting in a front suspension or resistance to squatting in
                  a rear suspension due to suspension geometry during acceleration. In a suspension
                  with 100% anti-lift/squat the moment about the side view instant center due to
                  weight transfer is exactly offset by the moment about the side view instant center
                  due to the acceleration force. See the following equations:
                      - Front Suspensions Live Axles
                      - acx = -(front drive ratio)/2
                      - dtwt = slr*abs(2*acx)/(diff
                          ratio)/track
                      - aczleft = -(cg height)/2/(wheel base) -
                          dtwt
                      - aczright= -(cg height)/2/(wheel base) +
                          dtwt
                      - Orientation A:
                      - dzfleft =
                          acx*(C(3,1)-slr*C(3,5))+acx*(C(3,7)-slr*C(3,11))
                      - dzfright =
                          acx*(C(9,1)-slr*C(9,5))+acx*(C(9,7)-slr*C(9,11))
                      - Orientation B:
                      - dzfleft =
                          acx*(-C(3,1)+slr*C(3,5))+acx*(-C(3,7)+slr*C(3,11))
                      - dzfright =
                          acx*(-C(9,1)+slr*C(9,5))+acx*(-C(9,7)+slr*C(9,11))
                      - dzwleft = aczleft*C(3,3) +
                          aczright*C(3,9)
                      - dzwright = aczleft*C(9,3) +
                          aczright*C(9,9)
                      - left anti-lift =
                        -100*dzfleft/dzwleft
                      - right anti-lift =
                      - Front Suspensions Fixed Differentials
                        base)
                        base)
                      - Orientation A:
                      - dzfleft = acx*C(3,1)+acx*C(3,7)
                      - dzfright = acx*C(9,1)+acx*C(9,7)
                      - Orientation B:
                      - dzfleft = -acx*C(3,1)-acx*C(3,7)
                      - dzfright = -acx*C(9,1)-acx*C(9,7)
                          aczright*C(3,9)
                          aczright*C(9,9)
                      - left anti-lift =
                      - right anti-lift =
                      - Rear Suspensions Live Axles
                      - acx = -(1 - front drive ratio)/2
                          ratio)/track
                      - aczleft = (cg height)/2/(wheel base) -
                          dtwt
                      - aczright= (cg height)/2/(wheel base) +
                          dtwt
                      - Orientation A:
                      - dzfleft =
                      - dzfright =
                      - Orientation B:
                      - dzfleft =
                      - dzfright =
                          aczright*C(3,9)
                          aczright*C(9,9)
                      - left anti-lift =
                      - right anti-lift =
                      - Rear Suspensions Fixed Differentials
                        base)
                      - aczright = (cg height)/2/(wheel
                        base)
                      - Orientation A:
                      - Orientation B:
                          aczright*C(3,9)
                          aczright*C(9,9)
                      - left anti-lift =
                      - right anti-lift =
                | F3 |
                RESULT(3) |
                Right Front Anti-Lift or Right Rear Anti-Squat |
                See F2/RESULT(2) (above) for explanation and equations. |
                | F3 |
                RESULT(3) |
                Average Front Anti-Lift or Rear Anti-Squat |
                The mean of the left and right front anti-lift or left and right rear
                  anti-squat. |
                | F4 |
                RESULT(4) |
                   Left Front Lift or
                  Left Rear Squat
                mm/g |
                The front suspension lift or rear suspension squat during acceleration or:
                      - Front Suspensions
                      - left lift = -(dzfleft+dzwleft+aczleft/(tire
                          stiffness))*weight
                      - Rear Suspensions
                      - left squat = (dzfleft+dzwleft+aczleft/(tire
                          stiffness))*weight
                | F5 |
                RESULT(5) |
                Right Front Lift or  Right Rear Squat
                mm/g |
                      - Front Suspensions
                      - right lift = -(dzfright+dzwright+aczright/(tire
                          stiffness))*weight
                      - Rear Suspensions
                      - right squat = (dzfright+dzwright+aczright/(tire
                          stiffness))*weight
                | F6 |
                RESULT(6) |
                Average Front Lift or Rear Squat |
                mm/g |
                The mean of the left and right front lift or left and right rear
                  squat. |
