Tire
                If the Graphics panel is not currently displayed, select the desired graphic by
                    clicking on it in the Project Browser or in the modeling window.
                The Graphics panel is automatically displayed.
                Click the Body collector and
                    select a body from the modeling window, or double click
                    the Body collector to open the Model Tree (from which the desired body can be selected).
                Note: If the selected graphic is a pair entity, first distinguish between the Left and Right tabs in the panel, and then edit the properties. When defining a pair graphic, use pair entities for Body, Origin, etc.
 - Click the Point collector (under Origin) and select a point from the modeling window, or double click the Point collector to open the Model Tree (from which the desired point can be selected).
 - Click the Point collector (under Direction) and select the spin axis of the tire from the modeling window or the Model Tree, or, using the drop-down menu next to the collector name, select Vector and choose a vector.
 - Click the Properties tab and enter the specification for the tire.
