A curve graphic is created by positioning a 3D curve entity (Cartesian or parametric
        curve) in a reference frame (marker). The reference frame can be an explicit marker or can
        be implicitly defined using a body-point-orientation method.
                If the Graphics panel is not currently displayed, select the desired graphic by
                    clicking on it in the Project Browser or in the modeling window.
The Graphics panel is automatically displayed.
                Click the Parent drop-down menu and choose the method to specify a reference
                    frame.
If Marker is chosen:
                        Click the Marker collector and select an
                            existing marker in the modeling window or the
                                Model Tree.
The curve will belong to the marker's parent body.
                        Click the Curve collector and select the 3D
                            Cartesian curve associated with the graphic.
                If Body/Point is chosen:
                        Click the Body collector and
                    select a body from the modeling window, or double click
                    the Body collector to open the Model Tree (from which the desired body can be selected).
                        Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                        Use the orientation options to orient the
                    coordinate system.
            Tip:
                    - Clicking [DC] allows you to view the direction
                        cosines' matrix for a coordinate system.
                    - The curve graphic is created using the X,Y, and Z data provided in the 3D
                        curve (Cartesian or parametric) with respect to the selected reference
                        frame.
                    - This curve graphic can be used to define 2D rigid to rigid contact or higher
                        pair constraints such as point to curve or curve to curve constraint.
