Disk Brakes Attachments
- Front wheel spindle revolute joint pair: Revolute joint pair between front wheel hub and front knuckle.
 - Rear wheel spindle revolute joint pair: Revolute joint between rear wheel hub and rear knuckle.
Front Disk Brakes Attachments
- Brake line pressure solver variable: solver variable front brake line pressure.
 - Wheel spindle revolute joint pair: Front wheel spindle revolute joint pair.
Rear Disk Brakes Attachments
Similar to front Disk brakes attachments (above).
