Perform Bulk Operations on Notes
- From the ribbon, click the Notes tool.
 - Select a single note or multiple by using Ctrl+ left-mouse click.
 - To move the selected notes around the screen, use drag-and-drop on one of the selected notes.
                To bulk edit the selected note(s), right-click on a note and select
                        Edit from the context menu. Edit the note's
                    properties from the floating Entity Editor.
Figure 1. Notes - Entity Editor
