Add a Note
                 From the Media ribbon, click the Notes tool,
                Note: A video or image must be loaded, as notes cannot be created in an empty window. -
                Click a point on screen where you want to create a note.
                Note "n" is added to the graphics area.Tip: You can also drag and drop an existing note to place it anywhere in the graphics area.
