The user interface provides you with a consistent look and feel when you are working in any application.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Apply annotations, headers, and footers to your video.
Compare video frames or overlay frames with other videos or images to watch them in flips.
Use the Notes tool to create on-screen label items and describe additional information such as media time and marker coordinates.
ON THIS PAGE
ON THIS PAGE
